Started priming and washing some BOS yesterday evening
Really solid job on the terrain and good progress on those vile BoS guys. I assume you’ll save the superior minis for last.
Im Painting BOS first because they are all the BOS-Models I ordered. I also got the Supermutants-Starter and the Survivor-Starter at home but will not start painting them until I get my Resin-Starterbox. I want to paint all the Mutants at once and all the survivors at once to be faster.
After BOS I will return to more terrain - Another settlement needs my help
Little update. Almost finished shading. Highlights and details will follow today. I think, I’m able to finish them tomorrow
You’re a machine.
How the time flies! It’s half past twelve and I have to work in the morning But I had to finished the Brotherhood-Group!
Great terrain!! I am curious on how you did the peeling paint? Was it the hairspray over the base coats, then paint on “wall” color and use a stiff brush to get it to flake like that?
Thanks! Yes, that was my technique, pretty simple.
Right on! Looks like peeling paint, and I see a lot of that being a house painter, lol! Brilliant!! Thanks for the reply!
Looks good! Is that TT Combat stuff?
All your building look awesome, I can’t wait to get started on my own I will be using all these for tips.
The Gas-Station is TTCombat, the busstops and the diner are from Multiverse gaming.
awesome works!
what technique or material did you use for this rust effect?
If you mean the crackeling effekt on the Busstops and Diner: This was achieved with carackeling spray cans from hardwarestore. You have to prepare the MDF-surface with several layers of water-thined PVA-Glue. I think 4 layers should do the job. If you use fewer it won’t crackle - like on the gas-station
If you mean the rusted Metalcolor on the Brotherhood-Powerarmors: Basecollor was Black Metal (Scale 75), inked with Nuln Oil (GW) and while still wett some Rust-Ink (Vallejo). Highlightes with Trash Metal (Scale 75).
my fault! ) i mean rust effect on the pipes
Oh ^^ Thats Typhus Corrosion (GW) drybrushed with Ryza Rust (GW)
Thank you! can`t wait until you paint Gas and Bus station ))
do you have youtube channel? ) it will be cool to seen work in progress!
