I used Army Painter Dark Tone. Was expecting the result to be somewhat darker than that based on my past use of Soft and Strong Tones. Black ink is a good suggestion.
A brown or bronze wash might work well also, allowing it to pool around protrusions and in divots in a natural way while maintaining the rust effect.
The rust effects look really good though even if you don’t do anything more with it.
I think when I get my models, I’ll try to use a similar method for the super mutants, the metal with the rust effect, then follow that with the wash to deepen the effect a bit.
Now you have me curious: Skin tone on the pipe rifle? Kind of an off white to peach range? Or something darker? What does that accomplish? Just trying to make it look old and a bit washed out?
Looking good so far!
If youve run out of white,maybe just choose a lighter shade of similar colour and mix that in gradually until you get desired tone?
looking good the skin of the Mariposa super mutants as they appeared in NV, yhea flesh tone washes are good for dirtying things up as they tend to be an off brown type color
That looks good! I went with a more radioactive F.E.V. look. I used a lot of bright colors and a bright yellow ink. All you need is some highlights, and it’ll pop.
