So, the 3d printer is up and running for about a day now. Thought I’d show off what I’ve got so far.
The shelves are the official ones. I really like them. In addition to the shelves themselves, I also have the vertical portions sitting off to the side right now. Enough to make five of the tall shelves. I plan to do up a set of the shorter ones too and will likely need to print a few more shelves to make use of it all. My plan is to do a mix of the shelves they supply with items on them, and some random bits of my own on some of the empty shelves to fill things out and make sure everything is visually diverse. NOTE: The shelves with items on them. you have to be careful trimming supports. The missiles of all things were really fragile. I broke one, but it was easy to glue the broken piece back in place.
The pack brahman turned out perfect. I was thinking about printing two, but decided for now to just do one on the off chance Modiphius ever decides to do an official model. If I ever need a second one, I can always print another.
The dead brahman was supposed to include a raven on it that never printed. Otherwise the piece turned out nicely and I have a couple of ideas for how to use it. I’m going to put it on a base and treat it sort of like an objective marker.
The safes are the official ones. I already had some, but have some plans for them so used the empty space on the build plate to print a few extra.
The raider with the base. For some reason the club she was supposed to be holding and her hand never printed. On the up side, I was going to cut the club away and give her a gun anyway, so that won’t be a big deal.
The model with the walking stick is supposed to be a trader, I intend to use him with the pack brahman. His face mask printed a little funny, but I’m still happy with him.
The vault dweller right beside the trader was actually the first print I did. Most of these items I printed as groups, that one I printed alone because I wanted to make sure the machine was working correctly before I did a bunch of stuff at once. She turned out perfectly.
The Bloatfly turned out really good. Unfortunately I was a little rough getting it off and managed to break the bug off of the barrel. It was easy to pin.
The Drumlin diner signs. One turned out good, the other didn’t. The pole and sign print together, and since one didn’t print right, and the other I have specific plans for that doesn’t involve the pole, I canceled the build before the poles could finish. I’m trying to think of anything I could use the warped sign for, the poles should be easy to find a home for.
Did three tool chests. I like them really well, they’re going to look great in any garage or work area.
In addition to what is pictured here:
I have a set of vertical pieces for the shelving. They were fresh out of the printer around the time I took the pictures so they didn’t get included.
The pack brahman was the second attempt. The first was a failed print by any definition.
I’m printing a mortar for the minutemen right now. I found a print file online for it, but there were two problems. 1. It didn’t look like it was going to fit my print area. and 2. It looked a bit big to me. I sized the whole thing down about 20% and I thought it looked much better. I suspect this will be something Modiphius will eventually make an official model for, when that happens I’ll find out how close I am for size.
I’m still sort of learning how to do all this 3d printing stuff. @robhistory is giving me some good advice on how to use the printer, so hopefully I’ll get better at using it with experience and guidance.
Coming up:
- I want to print off a few Coupe cars, at least a couple.
- Short shelves.
- I have my heart set on doing up a proper diner. Problem is that the fine I have is just a LITTLE bigger than my build area even cut into the pieces the designer has it in. As such, I need to figure out how to cut it into more pieces. Odds are I’ll have to print it in four pieces to make everything fit on the printer, then I’ll end up gluing it all together once it’s done
- I have a lot of models downloaded from Thingiverse that I want to print, but as I put a dent in that list, I’ll likely be wading into some more of the Modiphius stuff. I REALLY want the Vault scatter bundle, so the next time I order miniatures I’ll almost certainly add that to my order. It looks like the Vertibird might be too big for my printer, so I’m struggling with that one. Worst case with the virtibird is that I’ll need to find a way to cut the file so it fits in the printer. The vault files themselves, I’m sort of torn on. Printing enough material to make a full vault would be a massive undertaking when it comes to time, but at the same time I’d like to have at least some of the official product, . . . I’ll think on it a bit and decide some time down the road, maybe after my “Print it” pile shrinks a bit.
