I did a few searches for this information using the search functions in the forum and didn’t find anything.
So, looking at the Courier - both his Perk and his ability Versatile are a little confusing to me. For Versatile - does a skill test include combat related functions like shooting and melee? I assume so, but wanted to ask.
Next, if you roll a cog on an action or get a VATs roll, you can spend these action points to generate only one of those dice of your choice? Or do you get all 3 at once? Or if you roll double bottle caps on a heroic VATs roll, can you spend both to either gain 2 (say, a green/yellow) or do you gain all three of the dice twice? I’m assuming it’s the former, as the latter sounds OP as heck.
I’m also assuming because you “spend” the action points, you “lose” the quick action you could take. Is that true?
Now the Perk - Companion. Whose LOS and presence do you use? The Courier, the unit activating, the highest/best, or players choice?
Like the Versatile ability, do you gain only 1 colored die of your choice, or one of each color?
What do you use these new die on? Any action?
And, say the Courier activated, does this or VATs rolls proc first? I’m curious because if he’s heroic he gets a VATs roll, so if the perks ability goes first, he can pick a color, and if he then rolls VATs, he can pick up to two others depending on the roll, so he can stack his dice. And assuming he gets a cog on the roll, he can pick one more from Versatile for the next action?
Colonel Autumn is up next. If he is Heroic, does this mean when he rolls VATs, he generates action points on either the nuke or the bottle cap now?
If he does use both die faces, does that mean if he’s on a team with the Courier above, and The Courier is also heroic, does he now also get both possible options?
