Periodically, Hobby Lobby has deals on their in-store model kits, and I had my eye on this particular model for a while – so when the next “40% off all models” rolled around, I got it. And then stuff happened and the box sat around on my work table for MONTHS. But FINALLY I got around to working on it!
Near as I can tell, this kit was originally from circa 1957 or so. With a bit of a Google search, I can find this same model kit in various forms, from various makers. At one point, it was billed as a military gas tanker (plastic parts in Army green) from Aurora Models, then Revell offered it up once in red as a “Mobilgas” tanker, then another time in a yellow-white scheme (not sure what color the plastic was) with “Shell Gas” livery.
This version from Atlantis prints the parts in green plastic and includes artwork showing it in “Sinclair” livery, with included wet transfers that can be used either to decorate it as a “Sinclair” gas tanker as in the art, or alternatively as a military gas transport (with wet transfers in white lettering that contrast well against a US Army olive green scheme). Although previous versions included clear plastic window inserts, this one does not.
Parts consist of a rig (with a cab that can flip forward to reveal the engine), and semi-trailer, plus two crew (one standing, one posed as if holding a hose as in the cover art), and one self-standing sign board (depicted in the cover art in the background bearing “Sinclair DINO Gasoline” with Dino the Dinosaur mascot in green).
Now if there were only a kit for that gloriously retro SINCLAIR service station in the background… (Actually, I’ve seen some diorama/model kits that might fit the bill, but they’re collectible and pricey.)
Assembly is somewhat fiddly in parts. The instructions are decent enough, but some of the steps suggested in the instructions seem counterintuitive to the order in which the parts should actually be assembled, particularly if you’re planning on painting. I had considerable trouble trying to get some of the parts to line up properly, perhaps due to plastic warping, and ended up having to use some epoxy putty in places for gap-filling – and especially to clear up the “dimples” in the plastic that appeared in places (along the sides of the main tank in the areas right above the connecting pegs, around the rims of the tires, and also a couple of depressions in the torso areas of the two included figures).
The rear view mirrors are particularly flimsy, almost certain to break in storage or with handling if this is used for tabletop gaming, rather than safely stuck away in a display box or as part of a diorama. One could probably get away with just leaving them off entirely (as I’m not sure that any of the Fallout vehicle STLs even bother with side mirrors), but I opted to make sturdier substitutions with some wire and epoxy putty.
