My preferred method for storing all miniatures, including Wastaland Warfare, is to magnetize the base, and place them on metal sheets upright. This has a few advantages over foam based systems:
Density - You can store about twice as many miniatures in the same volume of space when it isn’t being filled by foam.
Cost - The cost of magnetic adhesive sheets, metal sheets, velcro tape, and transparent plastic stackable boxes add up to less than buying specialized foam cases.
Convenience - Not only is it easier to get minis in and out because you literally just pick them up, but if you store them in transparent plastic containers like I do, you can just look at the outside of your boxes to find the right box that has what you are looking for. No need to unzip foam cases, take out the inserts, and rummage through them looking for the right miniature.
Flexibility - Once the miniatures are magnetized, it’s easy to transfer them from case to case. I don’t have to worry about having a foam cut-out space that matches the dimensions of the miniature. This makes it easy to say, store all mini’s from one game in one big container, but when traveling to a game night where you only need a handful, transfer them to a smaller box. I’ve seen people that buy dresser drawers and put metal sheets in there to store mass amounts.
The downside is that it you don’t get quite as much protection. I wouldn’t use this method if I were going to ship a package of assembled/painted miniatures that is going to get tossed around a lot. I can turn the cases upside down and the mini’s will stay in place. But if I shake them violently, they will come lose. I find this is enough protection for everyday purposes and to put them in the trunk of my car without worrying about them. But if I were worried about children or animals that might be really rough with them, this wouldn’t be so great.
Some bases, like the ones that come with Infinity miniatures, have a recess on the underside that is deep enough to superglue a small, rare-earth magnet to the underside of the base. This is what I do if I’m able to.
In the case of bases that are flat on the bottom like Fallout, I buy flat magnetic sheets that are adhesive on one side. I just stick them to the bottom of the miniature and then cut around the edges with scissors. Even though the magnetic sheets are weaker than rare-earth magnets, if the diameter of the base is big enough in relation to the weight of the miniature, they still stay in place unless you shake them quite a bit.
Here are the magnetic sheets that I buy:
Here are the metal sheets I stick them to:
The plastic containers that the metal sheets fit inside:
I use velcro tape to secure the metal sheets to the containers:
That should be all you need. You can get different sizes of metal sheets and containers. If you do, you’ll want to pick up some tin/metal snips to cut the metal sheets if you need to fit them into a container like this:
