It says that Final Action is Move away from LoS, what will happen if 1st action is Strike (Charge)? Will 2nd action be Move which will waste the charge action? When does the Final Action be triggered? It looks to work for ranged but not melee
Hey,
Could you grab me a picture of the card so I could check this for you?
Hey,
Going to need to chat this one over with one of the rules folks. I’ll get back to you once I have an answer.
Thanks for bearing with us.
Hey,
So here is what I have;
- The Final action clause there only comes into effect if the first action was not a M. If the first action was M, they would generate their final action as normal.
- The Final action clause would trigger whenever that model is about to take their final action. The clause beneath it regarding ranged weapons has nothing to do with the final action clause. It just means that any models affected by this card will use their Ranged Method over any other method.
Thanks a lot for this
