Is there a way to enable Light theme(s) for the forums?
You can change this if you want - thereās a setting in your preferences panel. (under āinterfaceā)
Now, hereās the caveat - weāve designed the site for the DARK & MOODY scheme, because it fits with the design of http://www.modiphius.com. However the light & cheery theme might not work as well, so please do give it a go and test it.
Let me us know here if you come across anything that breaks the site!
Have a Beta Tester Badge as a thank you!
Thanks, I didnāt notice this somehow. I switched it on, and the first thing I noticed is that there are threads where the font is not readable. Check it out:
Darn.
Like I said - we havenāt built these forum to support that Light Theme (which, Iāll be honest, I just turned on for you now )
If you can log the things you see that donāt work with the Light Theme turned on, we can use it as a list for our dev to try and fix when we next patch the Forums.
Thanks for the help!
Thank you very much for turning the theme on just for me
I will post updates here if I find something else not looking properly.
Thanks for those new forums !
Indeed, it feels like theyāre made for the Dark theme and not so much for the Light one, for exemple the little image at the top that says āModiphius - Forum - Betaā only says āForum - Betaā (as āModiphiusā is in white letters) when we turn on the Light theme
Err⦠yeah⦠thatās because weāre so modest we donāt need a logo??
Thanks for spotting that though!
I canāt read it in Light mode because there is a black background image and the text over top is black/grey as well. Itās fairly user-unfriendly in Light mode.
Weāre looking into what is exactly required to get the light theme usable. Currently itās very much āuse at your own riskā. However weāll add this feedback to the list of things that need to be altered for it to be usable.
Thanks! And have a Beta Tester badge for being brave enough to use the Light Theme!
A fully functionable light theme would be very useful to me. I donāt know if it happens to other people but if Iām reading white text on a black background for long periods, if I look away I see ābandingā across my vision which eventually begins to affect reading the screen.
Its one of the reasons why I canāt really read the non-PF versions of the STA PDFs for anything other than quick referencing.
Thanks for the feedback - the fact that the current light theme is pretty broken is definitely something we want to address.
If thereās any particular part that youāve noticed needs special attention definitely let us know here!
As soon as there is any news regarding this rolling out weāll announce it here.
