Hello!
I have a question about JET PACK mod card.
- You can fly to the roof if it is lower than Yellow. Agility is tested?
- Can I fly into the 2nd floor window if it is lower than the Yellow one? Agility is tested?
Sorry I do not speak English used by the translator.
Hi @Altaris
The answer to both your questions is Yes. Since the Rules on the card state that you can move ‘up to Yellow’ anything below that is all good. You also don’t need to test agility when doing this as the movement is ‘without considering difficult and/or impassable terrain’.
Hope this helps.
Modiphius-Nathan
