Continuing the discussion from Into the Vault errors & questions:
I don’t understand yet the 2nd image from the example in p.3, even after deleting this doorway.
Armory room card is 2x2 and 1 Doorway, and the example 2 puts 2 Doorways in the room.
It explains what could happen if you put a Doorway along a Wall (example 2, so you could possibly generate a third room wich connect both rooms) or what could happen if you put it in the other Wall (example 3).
I don’t understand the bottom left Doorway at example 2.
