Does anyone know if Modiphius has made any maps from the source books available in high resolution versions? I’m building some pages in Roll20 and was hoping to use the Zingara map from Conan the Pirate and allow the players to move the party around the map. The resolution from the PDF is ok, but more is better.
There are no map packs available that contain high-res versions of the books in the PDFs. And I don’t think it is necessary, as the resolution as you said is OK per map, when you copy it from the PDF and not do screen crop.
