Quick question everyone:
If a character takes 2 points of harm (either 2 wounds or 2 trauma), what happens with the difficulty.?
a) difficulty increases by 1 on all relevant attributes?
Or
b) increases by 2 because the character suffered two wounds?
Thanks in advance guys
ThiefofSouls
I would say the difficulty increases by two steps, once for each Harm.
If it is 2 wounds then difficulty on physical skill checks is increased by 2. If 2 trauma then the same for mental/personality based checks. If it is split between them then all skill checks have their difficulty increased by 1.
Official Answer:
Each Wound you have increases the Difficulty of all tests using Agility, Brawn, or Coordination by +1. So, two Wounds means +2 Difficulty. This caps out at +3, as the fourth Wound leaves you incapacitated.
Similarly, each Trauma you have increases the Difficulty of all tests using Intelligence, Personality, and Willpower by +1, so two Trauma means +2 Difficulty on those tests. Again, this caps out at +3, as the fourth Trauma incapacitates a character.
And because base difficulty on most undefended attacks is 1, taking 1 wound and then attacking makes difficulty 2 base.
