Anyone else having issue printing the new pack " Fallout: Wasteland Wafare - Print at Home - Metal Dome" ? I have a Anycublic Mono 4k but the pre supported models either fail or do not fit on the build plate. The “STL_[FO]Metal_Dome_Pipe_02_Supported” is too big with supports to fit on the bed and the “STL_[FO]Metal_Dome_Pipe_02_Supported” barely fits but failed to print (several times it broke from supports). Plus the models all need to be repaired when brought into the slicer (using latest version Anycubic Photon Workshop). Just wondering if maybe others see these issues?
I got an elegoo mars pro and had to scale down the rocks to 97% to make them fit.
The pipe wasn’t a problem. Had no problems with the files themself.
