So if a roll has an applied focus it can score two successes (basically the focus increases the crit range). And a roll or 1 counts as two successes (a natural crit). What if you have an applied focus and you roll a 1?
I usually explain this as the critical success target being a range. The standard range for a critical success is 1-1. If you have a focus however, this increases the size of that range to equal the discipline score (1-4 as an example.)
Using that, there is never an instance where a place can score “better” than a 2 point critical success.
