That is how I understand it:
Every item you buy for a single Lifestyle Acquisitions test adds it’s cost to the total cost of this acquisition.
Restriction 1-2 items are purchased at no increase in difficulty (although the price must be paid for each item) Restriction 3-4 items increase difficulty by one, and Restriction 5 items increase difficulty by two.
For the MP-105 Reloads mentioned above, the Restriction is 2.
If you buy a single Reload, you have to succeed at D2 Lifestyle test and then roll your Earnings DSD against a Cost of 1.
If you buy 4 Reloads, you still only have to succeed at a D2 Lifestyle test, as this is a common type of ammo, but you have to apply cash by rolling your Earnings DSD against a Cost of 4 now.
At least that is how I had handled it (before returning to use “real money”, as in using the old monetary values, costs and earnings from MC2 and MC1, given in Cardinal’s Crowns. That made things so much easier and more convincing in play than the overly abstract Acquisitions rules).
I’m also not a big fan of the abstract ecomics. I only use the asset value as a reference of whether the PCs are able to do big purchases, like a car etc.
I don’t bother doing so for reloads or small purchases.
If I wanted to play a campaign / scenario where the players would be cash strapped and where money spending is important, I’d do as FrankF and use the old edition prices.
I still use the lifestyle roll to see if they can get their hands on very restricted items.
And here I am with a question once more, to make sure I understand vehicle rules correctly.
The issue I have considers a single crew vehicles. I understand that in that case that character counts as a commander and can take actions of any role, that much is clear. The doubt comes from the following.
“Each vehicle receives a single turn. During that turn, the vehicle
receives a single action per crewman, with the available actions
defined by each crewman’s role.”
This does not suggest the same split betwen Standard-Restricted-Free actions as a basic combat rules. However further descriptions of specific actions do specify whether they are Standard, Restricter or Response actions.
Given the above I assume the character in a single seater vehicle (say AZH-15 Raptor fighter jet) can take a Restricted Action from the pilot list - Standard Motion action, followerd by a Standard Action from Gunner role list - Open Fire or Firing Solution.
Other reading, that a single crew member gets a single action of any kind and that is all would mean that such an aircraft can’t ever actually fire, since it is forced to take move action by the Aircraft quality. So I am pretty certain in my interpretation, but I wanted to confirm it just to be 100% sure.
If you don’t mind putting a bit of translation effort into it, here is our price list we used in our MC3 campaigns - it is in german, but most items you might recognize from their english names.
The prices were calculated based on the acquisition stats in MC3 and the prices in MC1 and MC2.
This list has been used in our campaigns for a few years now, so it does work in actual play quite well.
I’m only now reading the Dark Legion campaign book, and yes it is very confusing.
But I’m of the opinion that since the section at the end, which is the only one to explain how the cure works, says there is only the one “Human Factor”, that’s what I’ll have to go with.
If I wanted to go with 2 different factors, I’d probably say you need the Ancient to get the superpowers, and the Human only works like the stimulant described in the beginning of the book. But then I’d have to think of a way to convey that difference to the players…
The other question is when they can apply the cure. Now, both the summary at the start of the book and the section at the end seems to assume it’s only the last Necromakina they find that is fully operational. However, most of the ones along the way have confusing descriptions that seem to indicate they’re at least partly functional. Also, the beginning of the book gives a D3 for the Medicine test to apply the cure, while at the end it only says D2…
I’m inclined to go with the lower difficulty since a failure kills the PC.
Also, I don’t know if I want the PCs to develop their superpowers at different points in the campaign. It seems simpler to just have them all transform at the same time, at the end. OTOH, it might lead to some interesting interplay if they realize what can be done early on, and that leads to competition within the group for who gets to go first… I’ll have to think about it some more.
