Infinity- Harm clarification
Hi there,
I just wanted to check how this worked.
So you receive harm if you have suffered 5 points of damage or the stress of the relative defense has been reduced to 0.
My question is regarding the 5 points of damage…does the harm come into affect when at least 5 points of damage has been done over all. Eg taking two points in one turn, then three in another would result in a harm?.
Or does the harm happen when 5 points of damage of been done in one attack, like some kind of critical hit?.
Thanks~!
If you receive 5 or more damage in one attack you take one Harm. But only if it’s the same attack. If you receive 5 points of damage in the same turn, but they resulted from several different attacks, they count as regular damage, untill stress is reduced to zero.
Thank you !, i had suspected but wanted to double check.
double checking is always a good idea
