Hi all
The Elder Scrolls Errata has been updated to version 1.1. The same package also includes the Print and Play cards to replace the misprints in the core set and a QRS of all the handy tables in one place. You can get it from:
G.
Hi all
G.
Thank you. I see a lot of cards that we don’t have. Are they from a different set? Cave Bear, for example. We are looking forward to the chapter 1 cards, maybe in there?
thanks
andy
Yup. This errata covers the ore set and the Chapter 1: Civil War card set.
G.
I am confused about the example for the new rule for limited use abilities.
The example given is for mjoll using sweep. It says the new rules limit her to only using sweep once per activation. If that limit were not in place, how would she go about using it more than once as she can not attack more than once per activation anyways?
Or is the limit of 1 referring to the number of additional targets she can hit? So basically sweep with a limit of one is like a normal follow up attack that is restricted to two handed weapons only?
Also, the chapter one card pack came with a second version of healing hands. It is exactly the same as the healing hands in the core set except it has the Aura targeting type rather than the Blessing targeting type.
Is the new healing hands meant to
1-replace the old.
2-the new target type is a mistake and we should use it the same as original.
3-they are both legal and it is meant to provide us with more options for healing?
If the answer is 3 I think it would have been better to change the name, as the spells function very differently as the original is a single target heal requiring los and the other is an aoe effect that can heal the caster, friends, and foes all at once.
Thank you in advance for answering these questions.
Does anyone know? Have these already been clarified somewhere else?
Hey RKO Adkins.
It refers to opportunities to do follow up attacks generated by the Sweep ability. If a levelled Mjoll were surrounded by, say, 4 Draugr and she removed the first with a successful attack, she can use Sweep to immediately attack another. If she removed the second Draugr as well, normally the Sweep Keyword could be used again, as she had successfully removed another figure. However, with Sweep (1) she has to stop, as may only use Sweep once per activation instead, only making one Sweep attack.
I’ll check on the Healing Hands card.
G.
Thanks for the clarification.
Have you looked into the healing hands card?
Got an errata update today in email.
If you guys are back in the office could you inquire about the healing hands? This card is driving me crazy.
Healing Hands is a Blessing, not an aura. The aura is a misprint.
Ok thank you very much.
Hi
I noticed in this that Ralof still has stealth in the endurance skill line, when it should be fact in agility. As I’m going to purchase chapter 1 card pack, is this fixed in the pack or will I need to print out the card once fixed online?
Yes, it’s fixed.
will these fixed cards be in the chapter 2 pack like how the core fixes were in chapter one? i’d really like official professionally printed cards
Chapter 2 card pack includes an update to the Orcish mace, but that’s the only card reprint.
ok thanks. will there not be reprints of the Hadvar and Darkeethus adversary cards (and similar ones with substantial rule errors) ever, or is that for the future?
In the errata for p. 41, Incapacitated (5th Bullet Point), does this Remove mean there was simply an asterisk typo, or are is the entire bullet point an error, meaning that models can indeed pay Upkeep while Incapacitated?
It’s just the asterisk. If you compare to the other bullet points you’ll see it was an artefact left over from typesetting.
There are no plans to update those cards in print form at the moment.
On the Darkeethus note, is the errata for his Histskin ability meant to also replace the way the Argonian race ability Histskin works in the book?
I doubt it; that errata is for the Adversary version of Derkeethus and it’s presumably just a change so that he will actually ever use that ability (because adversaries don’t generally do Special Actions). I’d imagine it will be the norm for other adversary versions of Argonians in the future, whereas player/hero models use the standard Histskin ability.
