When calculating points scored toward the requirement to defeat an opponent, in the core rules it says…
…you may spend 2 points of Momentum to increase the Quality of the asset by +1 for that attack only. (p. 167)
Meanwhile, in Wormsign, it says:
Momentum can be spent to add to the points scored (1 extra point for each Momentum)… (p. 9)
I have two questions:
- Which rule is right, core rules or Wormsign?
- If the answer is the core rules, may I spend 2 Momentum multiple times to increase Quality even more, e.g. spend four Momentum to gain Quality +2?
Thanks, Erik
