Hello everyone, I have some interrogation about banishs a horror alternate effect from summon a horror spell.
On page 186 (GM book) the description of Banish a Horror is a D1 test and momentum spent on success reduces the horror’s resolve by 3 combat dice “in addition to the normal counter magic rules, modifying that struggle”
I am a bit confused as to how banish a horror should be used. It seems like the description suggest you should use your momentum pool and throw a large number of dies at the horror and hope to hit the maximum of two traumas per attack.
Basically it’s a single target horror only mental damage spell? And cannot be used to “banish” a horror? It’s either standard summon a horror counter magic while it is being summoned or single target attack if it is already here?
and about the “in addition to the normal counter magic rules, modifying that struggle” How would rolling 3 combat dice on the horror while trying to counter magic work? If the counter magic fail we can at least damage the horror? But if the struggle fails then we have 0 momentum left?
In the conclusion of vultures of shem (p378) it is said “the spell Banish a Horror could be used to dispel […]” while protecting the caster from the threat of what they are trying to dispel. So it’s not a counter magic because it’s already there. By dispell should we understand that they cast it repeatedly until it dies of trauma? But then why wait two turns and not have them roll dices for every cast as a player sorcerer can be involved? Or is there a way to actually banish a horror that I fail to understand? It would be weird to go “well yeah it was possible during that story but not anymore”
In our team there is a player with the summon a horror spell and I want to offer the banish options correctly.
Thanks.
