The Pipboy item is a gear card and in the CRB it says gear items are limited use. Can the pipboy be used persistently through scenarios?
The cost of this item is calculated as if it is so.
As if it can be used through multiple scenarios (Settlement mode) or that it is limited use?
as item that not discard after using
Thank you. A gentleman and a scholar.
