Enthrall spell?
I’m currently running a Conan campaign, and designed an encounter which involves the use of a Crawler from Horrors of the Hyborean Age. The creature has an ability which says “The crawler may spend 3 Doom to use the Enthrall spell, as if it were a sorcerer”, however, I cannot find any information anywhere about an Enthrall spell. Could someone point me in the right direction?
I can’t find any spell called Enthrall in any of the books. Sounds like they may have meant the Enslave spell (core book pg 177). Interestingly the first line of the spell description says “Enslave is a common spell, known under many names throughout the Hyboran Age kingdoms”
I bet it is Enslave… the meanings of the words are very close to each other and unless you go into extreme semantics probably Enslave will work for you :slight_smile:
I was thinking enslave as well. Just wanted to be sure. Thanks everyone!
