yes to a certain extent treat it as shooting but iirc do not randomise if attacking into combat nor apply bonuses or negatives for doing so or indeed cover
The Old Badger is correct. To add to what they said:
It can be at up to Orange distance (as well as in BtB). The FAQ (Weapons and Attacks section) contains details on how a ranged melee weapon is resolved so be sure to check that out.
Engaged requires bring base-to-base.
That would be up to you to decide with your opponent before play starts in the same way as designating what terrain counts as cover. Some terrain that counts as cover for Normal models may not count as cover for a Behemoth.
thank you both for answers! it is clear now )
what about question 4 and TheOldBadger`s answer to it? Push back from the FHB will be very cool thing ))if it PB - where it is written?
relooking at the card it looks like it is AOE but since you can place it orange away 2" and it is 4" diameter then it should not hit you … it’s the nuka bottles that cause push back
What TheOldBadger says is correct. The critical of the Fire Hydrant Bat is area effect damage and if it is positioned so it overlaps the person using it then it will damage them too, the same way firing a Missile Launcher at a target that is very close or dropping a grenade next to you will do the same.
Great. Just to clarify the details of the Fire Hydrant Bat: The special effect that can be caused by a bottle result is Push Back (page 36, Rules of Play) and the critical effect is area effect damage.
