XP, Advancement, and Pacing
If I’ve read the rules correctly (no guarantee), then it looks like characters should be earning 25-75 XP per hour along with up to a maximum bonus of 50 XP/session. OK, so for a 4-hour session that’s 100-350 XP (average 225 XP).
Now advancement…
Attribute Improvement seems clear, and 100 x new rating gives values from 700-1400 XP for an advance, so it might be possible to raise one every 3-6 sessions if you’re not raising anything else.
Skill Improvement is also very clear, but it seems very expensive. Raising a 1E/1F skill to 2E/2F is 800 XP, but it can go way up from there.
Talent Improvement is clear even if the adjustment for Focus can require a little adjustment from the simple formula of using multiples of 200 XP. In many cases, early Talents can be the cheapest and fastest advancements to take.
Overall, it looks like the game is intended to allow (very?) slow and gradual character advancement. That’s not necessarily a bad thing, but with this in mind, how fast is advancement really supposed to go both in-world and at the table? Conan gains thousands of XP in each stage of his life (i.e., Barbarian, Thief, etc.) which range from several months to a few years of in-game length, but how many sessions would have been used to play out a given Conan adventure? Is each Conan tale really supposed to be 10-20+ sessions of play? If XP are being given to Conan for adventures done “off-page” in the transitions between, should PCs be given similar awards?
I have been running a game for 12 sessions now. I give 200 xp plus a bonus of 50 to one player each session. This has lead my players to ration their advancement and gives weight to every decision they make as they progress down their chosen paths. You can’t really measure the xp by the conan characters included. I am fairly certain those are intended to be examples of progression as well as add flavor so we can see where Conan was during that stage of his life.
Considering that the game is supposed to allow players to become legends like Conan and that they bother to show his progress (along with mentioning that he’s earned thousands of XP), it would be nice if that progression could be emulated.
How many days/weeks/months in-game have those 12 sessions taken? In that time, it sounds like each character has earned about 2,500 XP which–by Conan’s standards–is fine if the in-game time is only about 3-4 months or so, but might seem weird if it only covered a week or if it was a year or more of in-game time.
We meet every other week so real time it has been months. In game the overall time that has passed has been a couple months. I honestly have little doubt that at the rate we are progressing my part will have earned thousands of xp to progress with by the time even an in game year has passed. So long as my players are happy (which I make the repeated attempt to verify and they have always responded with a resounding yes) then I am satisfied as well.
Hello, are you sure that experience points should be given out every session, and not a module? Our master seemed to translate the rulebook into Russian for himself, even before the official translation, and said that experience points are given out every module. Approximately 250-300 per module.
And he also gives out 1 destiny point at the end of the module. There are 3 of them when creating a character. He doesn’t give them to us at other times.
May you explain this to me? It’s right the rules or not?
Fortune points refresh to the rate set at character creation every session.
Normally, all PCs get 3 Fortune points at the start of a new session. They can earn additional Fortune points during the session to a max of 5 Fortune points.
If a player decided to permanently sacrifice a Fortune point at character creation for an additonal Attribute point or skill ranks, then this character starts each session only with 2 Fortune.
But, this is a Fortune point refresh, so every session it resets to this value.
If your GM hands out Fortune points only rarely, that is quite different from how the rules are written or intended.
And it is intended that a player will be able to earn additional Fortune points during a session. Actually, the GM is supposed to give each PC the chance to earn a Fortune point per hour of game play.
And as a player, if you decide to use your character’s Trait in a hindering way, you will earn a Fortune point. And if you decide to voluntarily fail a skill test, you will earn a Fortune point, too - and add 1 Doom to the Doom pool.
The game is designed to use, to spend, to earn and to award Fortune points often.
XP can be given out each session. They are earned each session, at the rate of about 50 XP per hour of game play time, plus some extra awards.
But as XP can only be spent during a Downtime Phase, it is alright handing them out after an actual adventure. You wouldn’t be able to spend them anyway until the next Downtime.
yes, we only spend XP during Downtime. But we get them only before that. And then in the region of 250-500 for the whole module (which last time lasted more than 10 sessions)
I read about it in the rules, but don’t get why so. Maybe our GM didn’t get this chapter right?
Or your GM wants the PCs to progress more slowly? - Conan 2d20 does have a MASSIVE power creep regarding the PCs becoming superheroic competent in very short time. So this might be a house rule for slowing down this power increase.
He didn’t talk about it as a homerule. He said it as an original rule, which is why I’m asking this question now.
Well, that is the quote from the rules book:
For a four-hour game session, each player character should
receive around 100–300 experience points, based on the
amount of progress, the level of teamwork, goals accom-
plished, and how well the players roleplayed their characters.
This implies an award after every session, and on average about 50 XP per hour played (the span is from 25 XP to 75 XP per hour).
