Errata feedback for Shadows of Atlantis?
Is there a place to give feedback on errata for Shadows of Atlantis?
I’m only just beginning to read the campaign, but have seen some errors already - the main ones being two issues with the “Basic Training - Surveillance” sidebar on page 19:
  1. It seems to suggest that having an Observation focus of sight will reduce the difficulty by one. This is incorrect, a skill focus doesn’t reduce the difficulty of a check.
  2. The thread addition to get 1-3 extra dice would be up to six threat, not up to three.
If I find any others I’d like to make sure the feedback gets to the correct place. Loving the campaign in what I’ve seen so far, and I’d just like to help in making the material better/accurate.
I’ll have a look at what I wrote over the weekend. It was one of the first sections I did chronologically.
It’s a difficulty 2 test (which should also be in the text), so it requires two successes. Also the Threat cost is indeed incorrect (1/1 2/2 3/3 so 3 dice would add 6 Threat).
Agent Frank Bailey, one of the pregens, has in his listed equipment a “Superbowl Ring”.
Taking this to not be an error, he evidently has encountered some kind of time vortex to come into possession of an item that didn’t come into being until 1967.
In the India section, Devika Savarkar and her Brides of Durga are listed as having bows that do 8 dice of damage. They have all the same qualities as the bow (not the long bow) in the Player’s Guide: range medium, piercing, salvo vicious, subtle, and reliable. I’m assuming this was an error and it should be 3 dice of damage like in the PG. I didn’t see anything in the description to warrant the extreme damage that is better than a heavy machine gun.
Curare poison tipped arrows??
Yeah probably not…
Not quite errata, but there does not seem to be any artwork for the five separate pieces of The Palladion, which there is a picture of the assembled device on page 9. I am a visual-oriented GM and make handouts for the PCs to collect, use, ponder over etc. I am finding myself doing Google deep dives for images that come close to the individual items descriptions.
Would it be possible to get an Errata created that has the assembled device and solo images of the 5 pieces? I believe that having those handouts would be of great benefit to others running the campaign.
Best regards,
DDTWIilson
Putting this here for potential reprints, or confused GMs - British Honduras is not in the southern hemisphere, nor even South America. I suspect those references carried over from the Peru-set version of the scenario from the original release.
