In the Note under the Hassassin Fiday career block on p83, it states “This version of the Hassassin Fiday replaces any earlier printed versions: even if a character is being created using only the Infinity Corebook, feel free to substitute this stat block for the version in core.”
This suggests that, instead of the Elective Skills from the corebook, a roll for Hassassin Order should be made, and the Elective Skills from the Order should be used (and the corebook Elective Skills are not available).
However, in the Hassassin Orders block at the foot of p83, it states “You may
also use your Order’s elective skills in place of the standard when working the Hassassin Fiday career”, which would suggest that the ‘standard’ Elective Skills from the corebook are still available instead of the Order skills (due to the use of the word ‘may’) …
Which of these is true? Are the ‘default’ Fiday Elective Skills still available, or is it Order skills only, even for Hassassin Fiday?
It also notes under Hassassin Examplar that, when repeating the career, you can continue in the same Order, or roll for a new Order (or pay 1 LP to choose your Order). Is this option to roll for a new Order also available for Hassassin Fiday, or are they stuck in the Order they first roll?
(Also, the Hassassin Exemplar career block (p82) is not shown as having the Prerequisite: Haqqislam Faction, although it is marked as having that on the career table on p79, though I suspect that was merely a matter of limited space.)
